![]() | Home > General (L494) > Dynamic Response Fluid |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 272 ![]() |
Edit -
DWA Member Since: 06 Jan 2022 Location: Scottish Borders Posts: 19 ![]() ![]() |
Hi, you should get a warning on the dash, don't remember exactly what it says now but if you get it you will absolutely know about it, when it's as low as you say it cant be far away from coming on, mine was leaking at NSF wheel, and very quick to pump out the fluid, pumped out 1l of fluid in 4 miles when it went to be diagnosed, I used this stuff as it was half the price of JLR fluid worked perfect and can be found on an online marketplace.
Cheers ordered and arrived saturday! Topped up and all good |
No problem, pleased you got it sorted out |
