![]() | Home > Technical > Range Rover Sport SVR |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Would certainly be easier to look under the bonnet first, rather than the cup holders.
BearJew Member Since: 08 Feb 2025 Location: London Posts: 13 ![]() ![]() ![]() |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
That's a much neater solution than having the silly loop inside the centre console. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Ok, timing chain on the passenger side has failed, in idol, the engine does turn, 70 degrees to the left then back to the right. Obviously to get to the engine and do the chain is an absolute nightmare and not many people will even touch it. |
Seems to be other than LandRover, no one wants to touch. Garages just want to do breaks and tyres these days, I’m thinking I’ve got a workshop. I’ll do this myself, just been looking the strip looks a nightmare, but I’ll take my time and just photo my way in and follow the way out. Stay tuned. |
This guy had the same happen.
That looks like the same issue they had way back, which L/R reckoned they sorted with modified chain tensioners, but obviously still have the same problem. Not actually the chain that fails but the tensioner which then allows the chain to jump on the sprockets, but I guess the end result is the same a stuffed engine unless very lucky.
What year did they ‘fix it’ ? |
Somewhere around 2012/2013 if I remember right, actually have the Vin. No somewhere the modified tensioners were supposedly fitted from.
Definitely not fixed
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 85 ![]() ![]() |
Maybe try a Jag indie as the 5.0 Supercharged XFR's had tensioner problems, it's the same engine.
What is the chance the engine is going to have taken damage, on the drive sat in idling?
Seen a couple now where the rear left cylinder is damaged beyond repair.
