![]() | Home > Technical > Range Rover Sport SVR |
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 85 ![]() ![]() |
I had similar on an XFR, it was the battery on it's last legs, a new one sorted the problem.
BearJew Member Since: 08 Feb 2025 Location: London Posts: 13 ![]() ![]() ![]() |
Hi buddy,
Maybe check the engine to body earth strap. A Cheshire expat in France.
Would that stop it cranking over though? Defo an issue at the moment on the driver side arch. I know this as I did the cables my self and used a boil it that was too small so had to run in to a block. It’s definitely not right but sorted all the dash cluster faults immediately. But never seen this one. The day before there was definitely a power loss, as I remember thinking I’m losing a plug. No coincidence. |
Engine to body earth poor connection will definitely cause a starter problem. I'm not saying it is that but it's worth checking if you have had work done. A Cheshire expat in France.
Power loss while driving the evening before it died a death though. Started up fine though the starter, then the engine stalled and cut off and didn’t return. That’s my issues the Earth short wouldn’t have caused the stall .. |
That's true. A Cheshire expat in France.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
Have you had the car checked for any fault codes?
Hi Col,
Another interesting day, no winch points and they can’t get it in neutral. So the RAC has been trying to recover it for 3 days now unsuccessfully. Sending a caterpillar track tomorrow. |
Is that because they don't know where the emergency transmission release cable is, or because the release cable is seized?
They can’t get to it. They didn’t say it was seized no col. where is the cable access? Under the car .. |
Unless it's changed it used to be accessed by removing the access panel in the botton of the drinks cup holder and lifting the red lever.
If it’s not there, it would be ontop of the engine.
