Home > General (L494) > Heated Steering Wheel Upgrade
RRSporter
Just finished this project, with a few lessons learnt, so I thought i'd share here, because sharing is caring as they say Wink
Short summary, you need the right bits and it's then dead easy.
1) Battery off
2) Remove airbag and wheel
3) Replace Clock spring (rotary coupler) behind wheel for heated version (LR084446) - wire is already present to from main car loom to plug into this coupler.
4) Fit heated wheel with correct loom (module) and switch packs, airbag back on and battery on.
Job done! Its a great addition for winter. As I said that is all there is to it in my case 2016 HSE. Difficult bit it getting exact spec wheel off ebay in decent nick. Most of them fail at this last point, else its expensive from LR new.
Get the right bits - 30 mins tops. 👍 3.0 SDV6 HSE L494
Post #590932 Sun Nov 24 2019 5:25pm
00by
thanks for this! With this change in weather it's something I'm looking into...
So if I manage to source a heated wheel, do I then just need the clock spring (I think the part number is LR084446 - yours had an extra 4 on the end) to complete the job?
Did you go direct to LR for this or find another source?
Thanks! MY16 RRS 3.0 SDV6 HSE Dynamic
Post #591470 Wed Dec 04 2019 4:06pm
carlos50
RRSporter, dont suppose you removed your steering wheel trim piece (the U shaped bit at the bottom) whilst the wheel was off did you? Im keen to know how it removes and if the airbag has to be off the car to allow it to release?
Thanks
Carl
Post #591506 Thu Dec 05 2019 1:13pm
RRSporter
00by wrote:
Thanks!
Hi part number typo duly amended - good spot!
I went to LR for the RH switch pack. eBay for the clock spring. It’s also fitted to vogue and evoque I think so they do come up. Heated wheel beware of a loom change I think in 2016. Later cars have wires spaced out in multi connector on the wheel loom. Earlier cars they are all in a row. Heated or non heated / active or std cruise makes no difference to
The pin outs on the multi connector. Model year does! The function buttons won’t work if you mix these two. Don’t ask me how I know!!
1st pic is factory fit my car prior. 2nd pic is wheel with incorrect loom (and incorrect cruise controls) for my car. As you can see there are a few combos to get right. You can change looms and switch packs, and as far as I’m aware any heated wheel will do provided you insert correct loom and RH switch pack. (This is all
Pre facelift obviously).
 3.0 SDV6 HSE L494
Post #591700 Tue Dec 10 2019 12:35am
RRSporter
Thanks
Carl
Didn’t touch this it’s part of the main wheel. I’d say it prob bonded on, possibly clipped on? Almost certainly needs airbag off as it tucks under though looking at a photo mid job. Cheers 3.0 SDV6 HSE L494
Post #591701 Tue Dec 10 2019 12:51am
sterling01
Scotland
Thanks
Carl
Go to 11:42 on this video. It just pops out.
 Current - 2020 Range Rover Sport P400e
Gone - 2014 Range Rover Sport HSE SDV6
Gone - 2017 Audi A8 Sport
Gone - 2007 Range Rover Sport HSE TDV8 - Great car.
Post #605771 Tue Oct 20 2020 1:59pm
Lml
England 2013 Range Rover Sport SDV6 HSE Stornoway Grey
Evening. Sorry to resurrect an old thread. Does anyone know of any different part numbers for the heated steering wheel clock spring ?
Post #612202 Thu Apr 01 2021 9:01pm
DesTW18
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
Report post
Hi Martin,
I hope I am not too late and am new to this forum.
Re the thread - you say to "get the right one".
I am looking at a heated steering wheel for my RRS L494 2017 on ebay, apparently it is off an Autobiography so am assuming it would fit. Do you have any thjoughts on what more I can do to ensure it "will work"?
Also, I spoke to a mechanic friend of mine a while back and he said it was actually quite a complex job (his contact did whjo specialises in RRS), needing software upgrades and a lot of faff with the wiring. Any thoughts much appreciated.
Thanks,
Errol
Post #646734 Thu Feb 06 2025 3:31pm
sterling01
Scotland
Hi
You need the clock spring specifically for the heated wheel as mentioned in point 3 at the top of this thread.
I didn't have to do any coding with the one I fitted to my old L494 Current - 2020 Range Rover Sport P400e
Post #646740 Thu Feb 06 2025 4:38pm
DesTW18
Many thanks sterling01.
I'll report back...
Post #646741 Thu Feb 06 2025 5:11pm
DesTW18
BTW does anyone have an inkling of what LR woudl charge to retro fit a heated steering wheel to L494 2017 3.0 SDV HSE? Am sure it would be mad money...
Post #646742 Thu Feb 06 2025 6:19pm
sterling01
Scotland
I'd think £2k wouldn't cover it. Current - 2020 Range Rover Sport P400e
Post #646743 Thu Feb 06 2025 7:21pm
DesTW18
Only "because they can"!
Post #646746 Thu Feb 06 2025 7:47pm
LesW
France
You will probably find that a main dealer will say it cannot be done as they don't do retro-fits.
I did mine a couple of weeks ago, a 2015 L494 and it was an easy 30/40 minute job. No coding required, it just worked and is a wonderful addition.
There's a bit more info in my post here, take note about the fuse; https://www.rrsport.co.uk/forum/topic62903.html A Cheshire expat in France.
2015 RRS HSE 3.0 SDV6
2015 Aston Martin Vanquish
2010 Jaguar XFR Le Mans
Post #646798 Sat Feb 08 2025 5:18pm
