![]() | Home > General (L494) > Heated Steering Wheel Upgrade |
00by Member Since: 25 May 2018 Location: Northants Posts: 81 ![]() |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
RRSporter, dont suppose you removed your steering wheel trim piece (the U shaped bit at the bottom) whilst the wheel was off did you? Im keen to know how it removes and if the airbag has to be off the car to allow it to release?
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 ![]() |
Hi part number typo duly amended - good spot! I went to LR for the RH switch pack. eBay for the clock spring. It’s also fitted to vogue and evoque I think so they do come up. Heated wheel beware of a loom change I think in 2016. Later cars have wires spaced out in multi connector on the wheel loom. Earlier cars they are all in a row. Heated or non heated / active or std cruise makes no difference to The pin outs on the multi connector. Model year does! The function buttons won’t work if you mix these two. Don’t ask me how I know!! 1st pic is factory fit my car prior. 2nd pic is wheel with incorrect loom (and incorrect cruise controls) for my car. As you can see there are a few combos to get right. You can change looms and switch packs, and as far as I’m aware any heated wheel will do provided you insert correct loom and RH switch pack. (This is all Pre facelift obviously). ![]() ![]() |
Didn’t touch this it’s part of the main wheel. I’d say it prob bonded on, possibly clipped on? Almost certainly needs airbag off as it tucks under though looking at a photo mid job. Cheers 3.0 SDV6 HSE L494 |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 137 ![]() ![]() |
Go to 11:42 on this video. It just pops out. Current - 2020 Range Rover Sport P400e Gone - 2014 Range Rover Sport HSE SDV6 Gone - 2017 Audi A8 Sport Gone - 2007 Range Rover Sport HSE TDV8 - Great car. |
Lml Member Since: 12 Apr 2015 Location: Cornwall Posts: 20 ![]() ![]() ![]() |
Evening. Sorry to resurrect an old thread. Does anyone know of any different part numbers for the heated steering wheel clock spring ? |
DesTW18 Member Since: 06 Feb 2025 Location: Surrey Posts: 5 ![]() ![]() ![]() |
Hi
Many thanks sterling01.
BTW does anyone have an inkling of what LR woudl charge to retro fit a heated steering wheel to L494 2017 3.0 SDV HSE? Am sure it would be mad money... |
I'd think £2k wouldn't cover it. Current - 2020 Range Rover Sport P400e
Only "because they can"! |
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 79 ![]() ![]() |
You will probably find that a main dealer will say it cannot be done as they don't do retro-fits.
