Home > General > 360 Camera SVR
SVRSVR
360 Camera SVR
I can see on the build list on the SVR I’m getting has both Camera Systems REAR VIEW CA
MERA and Forward Facing Camera.
I asked the dealer to send a photo of the car in reverse but cannot see the 360 option, I'm told some updates have caused 360 to disappear.
Is 360 standard on 2018 SVR facelifts? Or was it an optional extra?
If I have forward facing camera does it mean I have 360 capability?
Thanks
Post #646513 Sat Jan 25 2025 12:51pm
SVRSVR
Just found out front facing is not a camera as such, just scans the road ahead for the emergency stop city brake.
Am guessing retrofitting 360 cameras is expensive?
Post #646514 Sat Jan 25 2025 12:55pm
I doubt it’s standard.
It needs cameras in the door mirror covers, facing down
Post #646517 Sat Jan 25 2025 1:25pm
SVRSVR
Retrofit possible?
Post #646518 Sat Jan 25 2025 1:46pm
Lindab
You will probably never use them. Had them on my previous Sport, probably used them twice. Much like Auto parking, never used. If retrofit from JLR, very expensive I would imagine Big Cry Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #646519 Sat Jan 25 2025 4:08pm
andygts
I'm with Lindab, never use it, had 360 and auto park on old L405, only ever used autopark to see if it worked. My SVR has 360 cams which thwn does it's fancy stuff and gives a top down view. I only use the reverse view really and wouldn't be bothered if the feature want there Current
2017 Range Rover Sport SVR
2011 Range Rover Evoque
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #646536 Mon Jan 27 2025 8:53am
360 degree cameras are probably only really worth having if you go off road or habitually navigate in tight spaces/narrow roads between lots of parked cars, kerbs, etc., where knowing exactly where the tyres and corners are will save expensive mistakes. 2012 SDV6 - it's missing a couple of cylinders
Post #646541 Mon Jan 27 2025 3:44pm
My old L320 has them, no doubt outdated compared to current system, only ever used them a handful of times in 12 years, and then only to have the rear camera on all the time to keep a eye on a trailer when towing one, or just to see if they still work.
Post #646551 Mon Jan 27 2025 8:17pm
