![]() | Home > General > 360 Camera SVR |
SVRSVR Member Since: 25 Jan 2025 Location: London Posts: 11 ![]() ![]() |
Just found out front facing is not a camera as such, just scans the road ahead for the emergency stop city brake.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5008 ![]() ![]() ![]() |
I doubt it’s standard.
Retrofit possible? |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 913 ![]() ![]() |
You will probably never use them. Had them on my previous Sport, probably used them twice. Much like Auto parking, never used. If retrofit from JLR, very expensive I would imagine |
andygts Member Since: 08 Jun 2024 Location: Yorkshire Posts: 16 ![]() ![]() |
I'm with Lindab, never use it, had 360 and auto park on old L405, only ever used autopark to see if it worked. My SVR has 360 cams which thwn does it's fancy stuff and gives a top down view. I only use the reverse view really and wouldn't be bothered if the feature want there Current
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 ![]() ![]() ![]() |
360 degree cameras are probably only really worth having if you go off road or habitually navigate in tight spaces/narrow roads between lots of parked cars, kerbs, etc., where knowing exactly where the tyres and corners are will save expensive mistakes. 2012 SDV6 - it's missing a couple of cylinders
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 ![]() ![]() ![]() |
My old L320 has them, no doubt outdated compared to current system, only ever used them a handful of times in 12 years, and then only to have the rear camera on all the time to keep a eye on a trailer when towing one, or just to see if they still work.
