Home > Wheels & Tyres > All terrain tyres for 2012 RRS 20 inch
Loharrison89
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Hi there,
I have a 2012 RRS and have recently purchased some new 20 inch wheels to replace my 22s.
I want to fit AT tyres to my new wheels and am curious on sizes.
My new wheels are 20inch x 8.5 ET35.
Would it be possible to fit 275 55 20 BFG K02s with no issues?
I have an easy lift module ready for installation to accommodate suspension adjustment.
Apologies regarding the question if its been asked many times but all the info i seem to read is conflicting regarding this size tyre and I am really eager to purchase the BFGs but am hesitant if there going to be an issue.
Cheers guys appreciate any input!
Post #646465 Thu Jan 23 2025 10:32pm
With that size tyre and wheel offset, I don't know but would think they would be pretty close to fouling the wheel arc. Diam. is nearly 80/90mm bigger than standard o.e 275/40 x 20" with a 53mm offset although they are 9.5j rims.
Post #646491 Fri Jan 24 2025 8:45pm
Loharrison89
Hi Col,
Appreciate the reply on this thanks.
Yeah agreed I was on the same thought process as you really regarding how close I would be on the arches when on full lock.
I have seen a fair few with the 275 55 20 installed specifically with the johnson rods so I was hoping I could make them work utilising the easy lift module to raise my suspension to accommodate the larger tyre however I am still debating how it would clear the arch even if raised 15mm or so extra on normal height.
Hopefully I can find some more info on here confirming.
Thanks again.
Post #646516 Sat Jan 25 2025 2:20pm
