![]() | Home > General > RRS 2012 autobiography rear entertainment screen issues |
RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 51 ![]() ![]() ![]() |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 ![]() ![]() ![]() |
Terraintamer Member Since: 24 Jan 2025 Location: Southwest Posts: 3 ![]() ![]() |
Thanks for taking the time to respond dean, I’ll take a second look at the module in the boot as you say it could well be a video out issue seeing as it is receiving image but with the colour distortion so possibly a faulty cable… I might look to find a new cable and quickly swap them out and see if that makes a difference failing that as you say it could be a modular failure. From what I saw today all appeared dry as a bone.
Thanks Col, massive help! |
Your rear entertainment module is in the drivers side rear boot space behind the panel under the side window in the rear.
Module looks to be Vin No. dependant.
