Home > Technical > L494 faults help!!
jaketm12345
United Kingdom 2013 Range Rover Sport SDV6 HSE Bonatti Grey
L494 faults help!!
Loads of faults on my l494 3.0 sdv6 2015
Lost communication to abs pump is the main fault is most modules, I carnt access for abs through snap on diagnostic, high speed can bus errors, I will post a picture of the faults I have on the dashboard
Good battery on the car with good voltage
Earths removed cleaned checked inside both wheel arches (no different)
Getting very lost with this now if anyone could help or lead me in the right direction would be much appreciated
Thank you
Post #646164 Wed Jan 08 2025 1:43pm
andygts
Is anything else on the can network missing?
compare to wiring diagrams and the first item in the line thats hasn't got comms I'd start there. Current
2017 Range Rover Sport SVR
2011 Range Rover Evoque
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #646186 Thu Jan 09 2025 10:29am
