Home > Technical > This isn't right |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
Can't see to well from the picture, but that looks to me as if you have it routed wrong around 8 and 9. The Alternator belt goes around 6,7,8 and 9. are you also sure they haven't given you the Air Con, P/S belt etc. instead as that would certainly be longer, although I don't know by how much.
Wed Jan 08 2025 9:06pm |
Axl Member Since: 20 Nov 2024 Location: Ayr Posts: 61 |
The photos aren't great sorry, i know what you mean but there's 2 on mine, a long and short one. This is the short one. It's the 3.6 tdv8. |
Wed Jan 08 2025 9:22pm |
The illustration I posted is for the TDV8 and shows the routing for both belts. Alternator belt highlighted in red.
Wed Jan 08 2025 9:25pm |
Ok
Wed Jan 08 2025 9:36pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
If you have the old
Wed Jan 08 2025 9:39pm |
The belt should be PQS500460 or equivalent brand i.e. Dayco, Gates etc. 6 rib 1360/1362 mm long.
Wed Jan 08 2025 9:45pm |
Don't have it it snapped |
Wed Jan 08 2025 10:06pm |
Ok This is the one I got at the local place I also think but not 100% sure that the reason it snapped is because the ace pulley is loose and i think sitting squint therefore it wasn't running true/ straight and got "cut" |
Wed Jan 08 2025 10:07pm |
Then I would suggest unless some pulley/idler etc. is actually missing which seems unlikely, then you have routed it wrong. Alternatively run a piece of string around the pulley's the route you think it should take and measure the length, that should give you a rough idea how long the belt should be.
Wed Jan 08 2025 10:16pm |
Can try that
Wed Jan 08 2025 10:42pm |
Looking at the Gates number it would appear to be the right one.
Wed Jan 08 2025 10:46pm |
Ok |
Wed Jan 08 2025 10:47pm |
