Home > Technical > This isn't right
Axl
2010 Range Rover Sport TDV8 HSE Adriatic Blue
This isn't right
I know I've got another post about this nonsense but thought to say this fresh that's all..
I was out at this contraption tonight and for the hell of it put the alt belt kind of on just to see how it would fit....I think it's too bloody long after the local factor saying it's the right one.
Unless I've got it routed wrong (and maybe I have) it's a if there's another pulley for it to go round. I hope you see the photo i attached as it shows it's to long plus there's a "bend" on the pulley of the ace pump. Honest to christ it's one thing after another on this bloody thing.
Post #646172 Wed Jan 08 2025 9:53pm
Can't see to well from the picture, but that looks to me as if you have it routed wrong around 8 and 9. The Alternator belt goes around 6,7,8 and 9. are you also sure they haven't given you the Air Con, P/S belt etc. instead as that would certainly be longer, although I don't know by how much.
Post #646173 Wed Jan 08 2025 10:06pm
Axl
The photos aren't great sorry, i know what you mean but there's 2 on mine, a long and short one. This is the short one. It's the 3.6 tdv8.
Post #646174 Wed Jan 08 2025 10:22pm
The illustration I posted is for the TDV8 and shows the routing for both belts. Alternator belt highlighted in red.
Post #646175 Wed Jan 08 2025 10:25pm
Axl
Ok
This is an online photo of what mine should be like, the same as yours just a different angle.
I did have it routed right but it's to long as you hopefully see in the photo.
Post #646176 Wed Jan 08 2025 10:36pm
If you have the old
Belt. Check the part number and compare the length
Post #646177 Wed Jan 08 2025 10:39pm
The belt should be PQS500460 or equivalent brand i.e. Dayco, Gates etc. 6 rib 1360/1362 mm long.
Post #646178 Wed Jan 08 2025 10:45pm
Axl
Andy K wrote:
If you have the old
Don't have it it snapped
Post #646179 Wed Jan 08 2025 11:06pm
Axl
Ok
This is the one I got at the local place
I also think but not 100% sure that the reason it snapped is because the ace pulley is loose and i think sitting squint therefore it wasn't running true/ straight and got "cut"
Post #646180 Wed Jan 08 2025 11:07pm
Then I would suggest unless some pulley/idler etc. is actually missing which seems unlikely, then you have routed it wrong. Alternatively run a piece of string around the pulley's the route you think it should take and measure the length, that should give you a rough idea how long the belt should be.
Post #646181 Wed Jan 08 2025 11:16pm
Axl
Can try that
Is mine the right one.
Post #646182 Wed Jan 08 2025 11:42pm
Looking at the Gates number it would appear to be the right one.
Post #646183 Wed Jan 08 2025 11:46pm
Axl
Ok
Post #646184 Wed Jan 08 2025 11:47pm
NoExpert
Looks very routed wrong. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #646208 Fri Jan 10 2025 2:22pm
Axl
It's ok it's been right since but has since snapped due to a faulty ace pump.
Post #646211 Fri Jan 10 2025 5:48pm
