Home > General > Heated Screen fuses |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5024 |
Have a look at the underside of the engine bay fuse box lid, they should be listed there, only from memory but I think they are 30 amp "J" type fuses the bulkhead end of fuse box, numbers 2 and 6 ring a bell, think they may be pink coloured with clear top, not sure which is o/s and which is n/s, but that's on the 12/13 cars but may be different position and type of fuse on 10/11 cars.
Thu Jan 02 2025 10:40am |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 407 |
Smashing - many thanks Col and 10/10 for random knowledge ! |
Thu Jan 02 2025 10:49am |
Just had quick look at wiring diagram, on a 10/11 car could try fuse's 15 r/h and 18 l/h still 30amp. Might need to check that they connected the N/S back up, connection is behind the "A" post trim.
Thu Jan 02 2025 10:53am |
15 and 18 is correct Col - both fuses intact. Will have a look at the connection behind the A Pillar trim. Does it just pop off ? |
Thu Jan 02 2025 11:14am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4999 |
there is a cap on the internal A pillar, marked Airbag, you pull this out slightly. (it's retained on a strap I think), and then undo the torx bolt behind it. maybe T25
Thu Jan 02 2025 11:53am |
Thanks Andy - to measure the resistance I complete a circuit using the battery, across each of the fuses ? Got a multimeter, using it to it's full potential is still work in progress !
Thu Jan 02 2025 12:18pm |
you put the meter into beep mode, or better still 200R
Thu Jan 02 2025 12:39pm |
Smashing - many thanks Andy. Will try at the weekend. |
Thu Jan 02 2025 12:45pm |
Some sun was shining into the car and warming it up a bit, so took the plunge on checking the screen connections. The AI fairies strike again !
Sat Jan 11 2025 11:36am |
