Home > General (L461) > Wiper blades rubbish
McTyke
Scotland
Hi all
So almost a year of ownership and 13k miles travelled. Very impressed with performance and economy. Would guess around 70% of those miles on engine. Is there a way of telling apart from scrolling through app?
Had it serviced recently which was oil and fliter - very expensive. Asked them to replace wipers as they are rubbish and leave an area just to left of field of vision smeared. New wipers are just as bad. Anyone else having any issues? 2024 Firenza Red P460e Dynamic SE
Post #645812 Mon Dec 16 2024 12:51pm
Lindab
clean the screen with a claybar. Clean the blades also (not claybar) Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #645814 Mon Dec 16 2024 2:00pm
McTyke
Scotland
Thanks - will give it a try 2024 Firenza Red P460e Dynamic SE
Post #645816 Mon Dec 16 2024 2:06pm
Lindab
I also use Rain X on the screen. Above 40mph, the rain blows off the screen. Below 40mph you only need the occasional flick wipe to clear the screen. I reapply every few weeks Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #645822 Mon Dec 16 2024 11:30pm
I use the RainX screen wash. 5L premixed from Halfords, poured straight in to the reservoir. Occasional use of Autoglym Fast Glass if/when a stubborn mark appears.
Works well and means at speed wipers aren't necessary except in heavy rain / motorway spray.
But the OP needs to just give the screen a good clean - Fast Glass does a good job of removing road grime. Don't forget to give the blades a wipe too. 2012 SDV6 - it's missing a couple of cylinders
Post #645827 Tue Dec 17 2024 11:24am
Tizzy
Just had my D350 serviced at 15K - overshot the 10k because they had no loan cars for months - service was fixed price £527 - a lot for an oil and filter change - but made the mistake of asking for new front wiper blades - which took the price to £601! Must be the worlds most expensive wiper blades at. £37 each! If I’d known how expensive they were going to be I’d have gone to Halfords and got the same Bosch ones for probably £37 for both of them! Lesson learned. In answer to the post, yes they had degraded in performance, the new ones are noticeably better but I also use RainEx screen wash and it’s pretty effective - also use it on the mirrors and it keeps these clean in wet weather as well. Out of interest Marshall Motor Group in Melton Mowbray have lost the Land Rover franchise recently
Post #645898 Mon Dec 23 2024 7:39pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
£527 for first service! Wow, got mine fixed at main dealer that have been around for years at £250. Same D350 ATB.
Post #645899 Tue Dec 24 2024 12:09am
10k service interval? Really? That's very short by modern standards. Yikes! 2012 SDV6 - it's missing a couple of cylinders
Post #645900 Tue Dec 24 2024 3:00pm
Tizzy
Apparently the MY24 cars have 10k service intervals
But it looks like they didn’t change the oil despite charging me £214 for 11L of Castrol Edge Professional - I know diesel oil goes black fast but not after only 6 miles?
Post #645901 Tue Dec 24 2024 4:02pm
JDPRRSUK
It does - very quickly. I would doubt very much they didn’t change it.
Post #645922 Thu Dec 26 2024 11:39pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Remove the oil filter and see if they replaced it. SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #645929 Fri Dec 27 2024 2:11pm
Dan_NL
Netherlands
Don't remove the oil filter : you'd need a new seal.
Just pass your finger next to where it is fitted, then pass another finger ( next to the first )
over the filter body and compare the dirt on both fingers. If the finger passing the filter
is much cleaner, they probably changed the oil, as you do not change the filter only..
Post #647041 Sat Feb 22 2025 7:39pm
