Home > My Range Rover Sport > L320 - wheel arch removal - corroded screws |
Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 16 |
I pulled the heads on the off, on screws holding my wheel arches on.
Sat Dec 14 2024 4:40pm |
jig Member Since: 14 Jan 2018 Location: London Posts: 40 |
so heads off then turn with pliers? thanks[/quote] |
Sat Dec 14 2024 5:01pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
Use a pair of mole grips,,, great bit of kit for jobs like that,, you will be able to lock them on, once you get a bit movement the jobs almost done 2010 RRS, TDV8
Sat Dec 14 2024 7:15pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4981 |
Use stainless steel screws and a bit of copperslip grease when replacing them. When I had nothing better to do I replaced a lot of the screws on mine with stainless makes it so much easier if you do need to remove them.
Sat Dec 14 2024 9:44pm |
Thanks mole grips failing to get a bit of the screw ;( |
Sun Dec 15 2024 3:01pm |
Thanks col noted and will do but still struggling to remove really don't want to destroy the wheel arch. |
Sun Dec 15 2024 3:02pm |
i lost the plot and attacked this with the dremmel to remove the head but failed looks bad
Sun Dec 15 2024 3:59pm |
