Home > General (L494) > Spacer Making Noises |
Nick900 Member Since: 11 Mar 2022 Location: Kent Posts: 82 |
You'd need to try and describe the noise. Does it sound rotational or reciprocal?
Thu Dec 12 2024 2:47pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 |
Probably a cooked wheel bearing made apparent with the spacers due to the additional strain on the bearings. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Dec 12 2024 4:53pm |
b1ecc Member Since: 19 Dec 2023 Location: North West Posts: 22 |
Wheel weights? |
Fri Dec 13 2024 4:20pm |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 161 |
surely if it was the bearing he would get the same noise with the second set of spaces tried. |
Fri Dec 13 2024 5:21pm |
Davenport Member Since: 17 Dec 2023 Location: Stockport Posts: 43 |
Slight irony Noexpert with your comments I did say there is zero drama with the standard setup,
Sat Dec 14 2024 9:33am |
If modification offends people that much there’s always mumsnet !!
Sat Dec 14 2024 9:46am |
When my wheel bearing died it made tinny squealing noises, not droning or vibrating. It could be early stages and the added offset makes it apparent, stock does not. Mine made me think I had a rock stuck in the splash shield occasionally. Took over a year to finally pin it down to the wheel bearing.
Sat Dec 14 2024 11:28am |
I’ll doff my cap if it’s a wheel bearing would be an elegant fix, wouldn’t expect to fail at 60k miles and 20 miles on a spacer…
Sat Dec 14 2024 11:42am |
