You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > General (L494) > Tapping noise from dash when accelerating, not from engine
Karlp606
So my L494 has developed a very soft tapping noise when accelerating, I originally thought it will be the engine but after inspecting the engine and listening whilst driving I can only hear it from inside the cabin and it sort of coming from behind the dash screen area. Its a very light tap/flap noise that increases with acceleration but then peters out once your past 2000rpm. You can only hear it with the radio and fan off.
Any ideas what it could be thats not engine related. Both manifolds were swapped earlier in the year also so I dont think its a manifold noise and I've had no errors on screen.
Wed Dec 11 2024 11:21am
Mac35
In my year of ownership I’ve come to realise where a noise sounds like it’s coming from can be quite deceiving. At first my rear differential noise sounded like it was coming from under the centre console. I first thought it was my transfer case.
Might be worth having a look underneath, check your front and rear propshafts and the rest of the running gear in that area.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
