With that in mind, I plan to not use the switch, but use the trigger wire, to splice into the full beam wiring of the headlight, so it comes on at the same time the full beam comes on.
Which wire is for the full beam?
I can find an earth point easy enough (lots of bolts to attach the earth wire from the harness to), is the live wire to the jump point (in the engine bay), bolted to the underside of the stud, so I can then bolt the live from the wiring harness to it?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
