Home > General > Normal Ride Height Only Message |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4418 |
Fault codes first |
Sun Nov 17 2024 7:49pm |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 165 |
Eh up Disco Mikey
Sun Nov 17 2024 7:59pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
I have had the same issue for a while now,, sometimes it's fine for days on end, then I might get the fault a couple of times in a day. Some time ago I rebuilt the compressor as was having other issues and all was fine for a good while then this issue surfaced. I was in the process of running a few tests,,, but life took over and it's been on the back burner of late. What I did find out when I was fiddling one day, was that the compressor had started as it should have, but cut out after a few seconds. I quickly removed the main connector from the compressor and checked for a supply,, and I was getting more than 12V,, but the compressor was not running. I think I am correct in assuming the main two pin connection is the supply to drive the compressor,, if it is live compressor should run?. Compressor motor wa quite warm at this time which leads me to think it is the motor itself at fault. These are permanent magnet motors and are not serviceable so in short the overall problem is the compressor unit,, but the item at fault is the motor,,.
Sun Nov 17 2024 9:20pm |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 248 |
Compressor on its way out, same thing happend to me.
Mon Nov 18 2024 11:58am |
Eh up gogsy1956
Mon Nov 18 2024 8:03pm |
Hi yes have a look on eBay for a replacement compressor any for a l494 will be fine - compressor is located under the spare wheel in the boot, easy to swap out disconnect everything reconnect should be all good.
Mon Nov 18 2024 8:14pm |
Eh up Karlp606
Mon Nov 18 2024 8:32pm |
Is yours a l494 or a l320?
Mon Nov 18 2024 8:34pm |
Eh up
Mon Nov 18 2024 8:39pm |
Check here matey , looks fairly straight forward
Mon Nov 18 2024 8:47pm |
Eh up Karlp606
Mon Nov 18 2024 8:57pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5004 |
I don’t think it will deflate from memory. But you need to take safe precautions anyway
Tue Nov 19 2024 8:55am |
Eh up Andy K
Tue Nov 19 2024 8:05pm |
Front valve block is easier.
Tue Nov 19 2024 8:35pm |
