Home > General (L494) > Reverse Camera Upgrade
Davenport
Has anyone fitted a plug and play upgrade to the standard JLR reverse camera? Looking for something with 720p resolution to crisp up the image…
This is the contender:
I just found this on AliExpress: £5.87 | BOENKAI Universal AHD 720P Backup Camera Wide Angle Flush Mount Reverse Rear View Camera Cars Pickup SUVs RVs Vans Reversing Aid
https://a.aliexpress.com/_ExQy9BF
Post #645217 Wed Nov 13 2024 1:30pm
Davenport
After a reasonable bit of searching there doesn’t seem to be any budget friendly aftermarket 720p compatible direct fit cameras. Can’t believe given how small they are how much they cost. Unless someone’s able to find a supplier??? Forced to stay standard (which I’m never comfortable with)
Post #645252 Fri Nov 15 2024 11:05am
Turdmon
Don't know the year of your motor, but I think the cameras were improved at some point. I have a 2017 using Incontrol Pro and I'm sure it is better than the earlier one (from what I've seen on Youtube). Mine is not bad but not a patch on the very latest ones with Pivi Pro.
Might be worth investigating and see if you can get a later one fitted, if you have a pre 66 plate.
Post #645285 Sun Nov 17 2024 7:49pm
Davenport
Hi Turdmon my thinking of aftermarket compatibility was OEM is pricey AF but there doesn’t seem to be products I can find competitively. Even PUK are £500 each for 360 cameras. It’s a nice to have so I’ll park it until something emerges…
Post #645328 Tue Nov 19 2024 2:14pm
