![]() | Home > General (L461) > Creaky/squeaky suspension |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 295 ![]() ![]() ![]() |
Nothing on mine. Quiet as a mouse 😉 |
bimjim Member Since: 17 May 2010 Location: Hertfordshire Posts: 90 ![]() ![]() |
UPDATE: This issue seems to have resolved itself, which is a bit odd but I'm not complaining. 2023 P440e Dynamic SE |
Perhaps unsurprisingly, the creaking has now returned.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Is it definitely suspension squeak and not tyre squeak? Dropping to access height might change the geometry slightly which could lead to the contact patch not being quite right to keep the tyres happy. When back up to normal height, the geometry is correct and the tyres happy once again.
Thanks for the suggestion, but I'm pretty sure it's suspension related. Rocking the car when it's stationary gives the same creaking noise. 2023 P440e Dynamic SE |
On older RRS, that creaking when being rocked would be an indication of a worn hub bush. I'd be amazed if that were the case on a newish car, however. But it's not impossible, I guess. 2012 SDV6 - it's missing a couple of cylinders
Indeed, it could well be something like, perhaps a defective part.
Harveyp500 Member Since: 08 Mar 2016 Location: Worcester Posts: 58 ![]() ![]() ![]() |
I get that too, always at low speed when coming out of or into tight parking spaces. not sure if it is the brakes or suspension or a bit of both. Either way, its on the list of things for Listers to look at. 2023 D350 FIRST EDITION, SANTORINI WITH CLOUD/EBONY
I can hear mine creaking if I rock the car from side to side, so it’s not the brakes on mine. It’s due to be looked at on Thursday. 2023 P440e Dynamic SE |
