Home > General (L461) > Creaky/squeaky suspension
bimjim
My car's just coming up to 12 months old and I've noticed that the suspension has started to creak quite badly while low-speed maneuvering in access mode. It's seems to be fine at any other height setting.
Annoyingly I need to use access mode almost every time I drive, in order to get it in and out of my garage.
Anyway, I'm finally booked in to get the wind noise looked at in a couple of weeks, so I'll see what they say then, but in the meantime I just thought I'd see if anyone else has experienced this? 2023 P440e Dynamic SE
Post #642205 Fri May 24 2024 6:14pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Nothing on mine. Quiet as a mouse 😉
Post #642209 Fri May 24 2024 10:16pm
bimjim
UPDATE: This issue seems to have resolved itself, which is a bit odd but I'm not complaining. 2023 P440e Dynamic SE
Post #642458 Thu Jun 06 2024 11:52am
bimjim
Perhaps unsurprisingly, the creaking has now returned.
I've got it booked in to be looked at. 2023 P440e Dynamic SE
Post #643758 Thu Aug 15 2024 2:47pm
Is it definitely suspension squeak and not tyre squeak? Dropping to access height might change the geometry slightly which could lead to the contact patch not being quite right to keep the tyres happy. When back up to normal height, the geometry is correct and the tyres happy once again.
Just a thought. 2012 SDV6 - it's missing a couple of cylinders
Post #643759 Thu Aug 15 2024 3:58pm
bimjim
Thanks for the suggestion, but I'm pretty sure it's suspension related. Rocking the car when it's stationary gives the same creaking noise. 2023 P440e Dynamic SE
Post #643775 Fri Aug 16 2024 11:08am
On older RRS, that creaking when being rocked would be an indication of a worn hub bush. I'd be amazed if that were the case on a newish car, however. But it's not impossible, I guess. 2012 SDV6 - it's missing a couple of cylinders
Post #643777 Fri Aug 16 2024 11:10am
bimjim
Indeed, it could well be something like, perhaps a defective part.
I'll report back once it's checked over. 2023 P440e Dynamic SE
Post #643780 Fri Aug 16 2024 3:45pm
Harveyp500
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I get that too, always at low speed when coming out of or into tight parking spaces. not sure if it is the brakes or suspension or a bit of both. Either way, its on the list of things for Listers to look at. 2023 D350 FIRST EDITION, SANTORINI WITH CLOUD/EBONY
2024 DEFENDER D250 110 HSE APACHE
2009 2.7 TDV6 HSE SANTORINI BLACK
GONE
2020 RRS P400e AUTOGRAPHY
2018 3.0 SDV6 AUTOBIOGRAPHY, CARPATHIAN GREY, SANTORINI PAN ROOF, IVORY INTERIOR. Now gone but will be missed, Cracking motor.
2015 3.0 SDv6 HSE DYNAMIC CORRIS
2014 3.0 SDV6 HSE FUJI WHITE CONTRAST SANTORINI PAN ROOF.
Evoque 2.2 d Pure Tech Auto
P38 4.0 HSE
Disco 2.5 d XS
Post #645031 Fri Nov 01 2024 6:08pm
bimjim
I can hear mine creaking if I rock the car from side to side, so it’s not the brakes on mine. It’s due to be looked at on Thursday. 2023 P440e Dynamic SE
Post #645034 Fri Nov 01 2024 8:25pm
