![]() | Home > Faults & Fixes > Fixed - slight movement in driver's seat base |
woodsie Member Since: 22 Nov 2015 Location: Milton Keynes Posts: 67 ![]() ![]() ![]() |
Thanks for that, I’ve got a tear/nick in my passenger seat back(about 30mm) been told I need a new seat cover.
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Likewise - also noting his details as I have the same kind of damage |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Great if it fixes the problem, however there is also a know issue with the electric seat mechanism, that can cause the same thing. Apparently the mechanism can move by a millimetre or two under acceleration or braking. The solution is to remove the seat base, and adjust one side of the winder. See here ...
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
There was a TSB for this but it was many years ago now. My first 2008 RRS had the problem. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
I have the same thing with my 2019 SVR, body weight transfer or my legs pushing into the cushion seems to make the cushion move with a slight clunk, so being an SVR with less padding in the seats Im assuming it’s the same issue, but that said I have felt it when braking hard so maybe it’s both, its is a Range Rover after all |
