Home > Faults & Fixes > L320 Suspension compressor**SOLVED** |
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 60 |
I have the same issue on my 2012 model, although luckily ATM it's holding in the normal position.
Fri Nov 01 2024 3:14pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
The cheap ones on eBay aren't genuine Hitachi, they are lookalikes,, if you read through the description they are branded as susfat or something similar and have a very limited lifespan in most cases I think. 2010 RRS, TDV8
Fri Nov 01 2024 8:04pm |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 221 |
I had one fitted in April ( AMK ) my indi will not use any others, just checked the invoice the compressor was £395.25 labour reprogramming etc £127.50 ( 1.5 hrs labour) VAT £104.55 total £627.30. Two years guarantee on the compressor. |
Fri Nov 01 2024 8:34pm |
jpvd Member Since: 30 Sep 2023 Location: yorkshire Posts: 27 |
Well think my choices are either:
Fri Nov 01 2024 9:55pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
The AMk is not better to the Hitachi - it is an alternative. Rebuild your Hitachi. 07MY RRS TDV6
Sat Nov 02 2024 8:07am |
Thanks for that, I'd better give those a miss then. It looks like I'll be stuck in normal height for a while longer then. My PB wouldn't release yesterday, so that's another job lined up too. That's not to mention front lower bushes and ARB bushes that need replacing. It only just cost me an arm and a kidney for the cam-belt. Why did I buy another bloody Range Rover? I should have listened to myself the last time . . . |
Sat Nov 02 2024 9:58am |
i would - but i have the feeling it has completely died and not worth fixing - it doesnt even turn on anymore and before this was rattling, so it maybe past saving....the AMK kit is cheaper from britpart and upon reading reviews runs differently to the hitachi and is supposed to be more reliable and better for the system, but the only pain is i cant fit it since it will require the ecu updating....so will cost me more to have installed....dammit...i usually do all my own jobs (just replaced a whole suspension on a bmw z4 this summer - which is a 2003 and was a nightmare of snapped bolts and rustd parts) so i know there will be rusted bolts and probably snapped bolts to deal with and i dont know if i can be arsed right now!.. ..might just bit the bullet and get take her to garage and let them sort it, install the AMK and new air tank too....then its job done! |
Sat Nov 02 2024 10:07am |
one quick question - sicne the compressor is not working, do i need to remove the fsue which controls the self levelling just to make sure it doesnt drop the suspension for any reason and then cant go back up?....if so which fuse(s) should i be pulling?
Sat Nov 02 2024 3:43pm |
