![]() | Home > General (L494) > Upgrading to either 12.3" or 13.3" screen |
Davenport Member Since: 17 Dec 2023 Location: Stockport Posts: 43 ![]() ![]() |
Hi Purvesh have you got photos of the 12.3?
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 284 ![]() ![]() ![]() |
Looks good a very like the latest Pivi offerings. Doesn’t look like it would restriction much airflow and it might be good to get some cool air on the back of the device anyway. |
Purvesh Member Since: 13 Jul 2024 Location: United Kingdom Posts: 7 ![]() ![]() |
This is the 12.3" screen. In your pic it hangs quite low as as I've gone for the non CD AC unit the screen is larger to the top is slightly covered. What's your audio output like I keep seeing that the screen uses different outputs depending on whether it's using the cars original interface versus Android etc Also have you used the original GPS or the GPS that comes with it? ![]() |
I really like the 12.3” integrated appearance it’s very trick but more costly with the new trim panel it requires from research I saw. Still tempted with the 13” jobbie. I’ve had an early Xmas present so able to purchase in the next few days. Last minute research is called for before placing an order. No idea I’m afraid at the moment on GPS or Audio.
I've sent you a PM that you'll find very useful mate! |
Falling at the 1st hurdle! Can’t even get the silver trim strips off either side of the centre console. The leading edge unclips but there’s no obvious direction it wants to go, a lot of resistance and nothing else is giving way. Used the dodo bars too don’t want to snap anything |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 90 ![]() ![]() ![]() |
Here you go
Awesome 🤣that explains it I started with the L405 process ripping them off from the front no wonder there’s no give. I’ve watched that clip months ago and forgotten all the key content for sequencing. Back on the right path now 👍 |
Right after a few trials and tribulations and significant assistance from a thoroughly good egg on here she’s in. What an absolute result it’s such a great upgrade transforms the interior removing the biggest tech weakness and moving it bang up to date.
Looks Fantastic great job Si! |
Cheers it’s early days learning to navigate android and all the functionality this thing brings. Screen resolution is absolutely ridiculous to the extent contemplating a reverse camera upgrade (in a separate post). Waiting in the car not a chore anymore with a myriad of apps to stream |
aero Member Since: 10 Oct 2018 Location: Melbourne Posts: 4 ![]() ![]() ![]() |
yeah i put in the 13inch screen as well, everyone is wow by it,
I've recently retro fit added 360 Cameras by a company in Bristol. Absolutely amazing! |
