![]() | Home > Maintenance & Modifications > Gearbox flush? |
Drop Bodsy a message. I wouldn't call him as he's always on the road and can't look at his diary whilst driving. Be persistent though, 07770 638023. 2006 2.7 TDV6 HSE in Cairns Blue. |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
Dont flush it can move |
tess Member Since: 20 Feb 2020 Location: sheffield Posts: 32 ![]() ![]() ![]() |
Flush or not to flush, well now I dont know what to think. |
Most ppl flush these.
Thanks Ive sent him a text |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
I got mine done at JAS in York. May be a bit too far for you though. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
A drain and refill doesn't replace all of the oil - much of it remains in the torque converter as your Jag nicely demonstrated. Flushing it replaces all of the oil. As for moving crud to unwanted places, it's no different to driving it - the flush machine is just plugged in to the cooler loop as I understand it and draws fluid out and puts fluid back as if it was just going out to the cooler. So crud shouldn't be any worse than otherwise. Mine has been flushed, the filter is, I think, original, and it's got over 150k miles on it and still going. (I hope that hasn't jinxed it!) 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
When doing mine the other week, Bodsy said his old D3 was on 275k having just had oil flushes and the unit still on its original filter. Impressive mileage none the less. 2006 2.7 TDV6 HSE in Cairns Blue. |
DorsetJag Member Since: 20 Oct 2024 Location: Poole Posts: 8 ![]() ![]() ![]() |
It's been interesting today, trying to get prices for a transmission fluid and filter change.
Had mine done at Quattro autocare in Riccall,, don't know how far it maybe from yourself. 2010 RRS, TDV8
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 123 ![]() ![]() |
Same here . Very good Indie if you ask me. ![]() ![]() ![]() |
Thanks for the suggestions, but based in Dorset so a local would be best. What did you have done? Flush or fluid drop/filter change? |
