Home > Maintenance & Modifications > Gearbox flush?
tess
Gearbox flush?
My SDV6 has done 110K miles, the shifts are not what they used to be & theres a juddering/vibration, Im in south yorkshire can you recommend a garage to do the flush/ oil change
Thanks
Post #640749 Wed Mar 27 2024 4:30pm
Stevepd
Drop Bodsy a message. I wouldn't call him as he's always on the road and can't look at his diary whilst driving. Be persistent though, 07770 638023. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #640755 Wed Mar 27 2024 7:30pm
Pistnbroke
Dont flush it can move Censored to places you dont want it . New filter and refill. How do you know its even full ?
My jag took 6.5 litres to re fill but only 3.5 drained out . Always listen to old people or when they die you will live on in ignorance.
Post #640766 Thu Mar 28 2024 7:08am
Pistnbroke
Post #640767 Thu Mar 28 2024 7:10am
tess
Flush or not to flush, well now I dont know what to think.
Post #640769 Thu Mar 28 2024 11:40am
Most ppl flush these.
Either way you will end up with a gearbox rebuild sometime on a 6 speed
Post #640770 Thu Mar 28 2024 12:39pm
tess
Thanks Ive sent him a text
Post #640774 Thu Mar 28 2024 1:28pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
I got mine done at JAS in York. May be a bit too far for you though.
Post #640779 Thu Mar 28 2024 4:32pm
A drain and refill doesn't replace all of the oil - much of it remains in the torque converter as your Jag nicely demonstrated. Flushing it replaces all of the oil. As for moving crud to unwanted places, it's no different to driving it - the flush machine is just plugged in to the cooler loop as I understand it and draws fluid out and puts fluid back as if it was just going out to the cooler. So crud shouldn't be any worse than otherwise.
Mine has been flushed, the filter is, I think, original, and it's got over 150k miles on it and still going. (I hope that hasn't jinxed it!) 2012 SDV6 - it's missing a couple of cylinders
Post #640782 Thu Mar 28 2024 5:34pm
Stevepd
When doing mine the other week, Bodsy said his old D3 was on 275k having just had oil flushes and the unit still on its original filter. Impressive mileage none the less. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #640790 Fri Mar 29 2024 6:55am
DorsetJag
It's been interesting today, trying to get prices for a transmission fluid and filter change.
My usual tech is nervous about quoting because he's never used the separate pan and filter kit before. He advised against flushing the box because of the risk of circulating crud.
The local LR specialist also advised against flushing for the same reason, but also won't change the filter because they had so many that refused to seal properly and leak. They claim it's been 5 years since they did a filter change but will drop the old fluid and put 5-6 litres of new in.
Then I spoke to another LR specialist who does a type of flush but without detergent, so basically they push out the old fluid with new with the engine running, until it runs clear.
None of them sound ideal but I'm swaying towards the last solution. Thoughts?
Post #644820 Mon Oct 21 2024 5:10pm
gogsy1956
Had mine done at Quattro autocare in Riccall,, don't know how far it maybe from yourself. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #644822 Mon Oct 21 2024 5:35pm
Kevin-t
Same here . Very good Indie if you ask me. Thumbs Up Thumbs Up Thumbs Up Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #644824 Mon Oct 21 2024 7:50pm
DorsetJag
Thanks for the suggestions, but based in Dorset so a local would be best. What did you have done? Flush or fluid drop/filter change?
Post #644828 Tue Oct 22 2024 6:50am
