Home > Maintenance & Modifications > 2013 L320 Oil Drain Mod |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4946 |
Looks to be Vin No. Dependent, is yours within the range?
Fri Oct 04 2024 8:20pm |
Heheshamon Member Since: 31 May 2023 Location: Leicester Posts: 14 |
Thanks Col so if it's below the DA814376 all is good and it will have the plug?
Sat Oct 05 2024 10:35am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 465 |
Yours is part of the TSB VIN range so it’ll all be as it should be.
Sun Oct 06 2024 4:51pm |
Thanks for clearing that up I had visions of me getting it jacked up only to find issues.
Sun Oct 06 2024 5:39pm |
As your vin. is within the affected chassis range, have you actually checked that the oil drain mod has been done? would like to think it had by now though.
Sun Oct 06 2024 8:41pm |
I've not yet but will before I buy the kit, having a few weekends off it now tbh the Mrs is getting jealous.
Mon Oct 07 2024 4:01am |
Got home early so squeezed under and it's the original long pipe.
Mon Oct 07 2024 1:11pm |
I'm a bit concerned about the oil I've used I used the correct spec 5w30 c1 but have read and seen videos of people using thicker oils as it is too thin.
Mon Oct 07 2024 2:19pm |
I’d be doubtful the oil change affected anything. The drain pipes seem to be fickle when they fail. I changed mine before it had an issue just because I could. The annoying part of the job is getting the starter out/out of the way to get to the plug in the block. Be sure to follow the instructions in the TSB and drain the oil out of the intercooler.
Mon Oct 07 2024 8:58pm |
