Home > In Car Electronics > New To Me 2018 SVR Connectivity Help
carlos50
Hi all
I just picked up a 2018 SVR today after a fair few years away from the RR world and first challenge lies ahead, it will not connect to my house wifi or my hotspot from my iPhone. It doesn’t find any wifi networks when searching and manual entry doesn’t work either.
When I connect my phone to the car and try and access Incontrol it says it’s not available, I have an active account and the Remote app is all connected fine etc.
I wanted to register my details in the navigation but it says I need a data connection but I’m struggling so far, didn’t want to sign on to a SIM deal when I’ve got masses of available data at home or via my phone and don’t intend to surf the net just wanted the connectivity all set up etc. and to check for system and nav updates.
Thanks
Carl
Post #644380 Wed Sep 25 2024 1:01pm
andygts
Is it definetly connected to incontrol?
If I remeber right I was able to sign into the car with my details but still couldn't access stuff, I had to get LR to deregister the previous owner and sign in again......LR were Censored and wouldn't do anything without a V5 either even though it states not proof of ownership across it.
The Nav side of things will need a data sim.
Nav updates are seperate aswell and cost more £££ Rolling with laughter Current
2017 Range Rover Sport SVR
2011 Range Rover Evoque
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #644381 Wed Sep 25 2024 1:53pm
carlos50
Yes it’s connected to Incontrol in the app/website, but can’t login in the car in the navigation section, it does have the previous owner recognised so I tried register rather than login, but then it said data connection needed to register.
In control is recognising my journeys in the app and website.
Post #644387 Wed Sep 25 2024 4:58pm
jimbg
Do you have a working SIM card? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #644388 Wed Sep 25 2024 5:01pm
carlos50
No I hoped to connect to my phone hotspot or my house wifi, is that the issue, it’s not possible?
Seems strange to have a feature to connect to external wifi then it doesn’t do anything Laughing
Post #644389 Wed Sep 25 2024 5:14pm
jimbg
Have you read this?
https://cdn.prod-row.jlrmotor.com/static/d..._en_GB.pdf 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #644390 Wed Sep 25 2024 5:31pm
carlos50
Not sure that helps, I definitely have an active Incontrol account, and navigation account, but can’t login to either in the vehicle because it needs an internet connection, which I can’t establish via external wifi and dont have a SIM card to try.
Im not trying to set up the accounts, just login to them in the vehicle.
I dont know why the vehicle can’t see any wifi networks at all, it just searches and finds nothing, even when I manually enter my home wifi network.
Amy ideas.
Post #644391 Wed Sep 25 2024 5:59pm
carlos50
When I try to connect to Incontrol in the car I get these messages
Post #644392 Wed Sep 25 2024 6:06pm
jimbg
What iPhone do you have and version of iOS?
What version of the infotainment do you have?
Have you spoken to the dealer about the previous owner? You are not going to be able to log in to someone else's car! Mr. Green Rolling with laughter 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #644394 Wed Sep 25 2024 6:48pm
carlos50
iPhone XR at IOS 17.7
I dont think the previous owner is logged in, the car is active in the Remote App for me, I mistakenly thought I couldn’t login to the navigation system because it had the previous owners name, so was trying to register. I tried again just now and went past their name to enter my own email & password, but it still just says I need an online connection to proceed.
The car is active to me, I gave an Incontrol account thats 100% functional in Remote and Route Planner, I just can’t establish an internet connection at the vehicle because it will not find an external wifi networks to connect to. I simply thought I’d hotspot from my phone as I have 60GB of data and barely use any of it each month, but the car won’t connect. It’s not because it’s connected to someone else, it’s connected to me, Im not fully connected to it because of this problem.
The supplying dealer won’t be able to help.
Post #644395 Wed Sep 25 2024 6:56pm
carlos50
One thing I noticed on the “about” section of the connectivity was the MAC & IEMI addresses were blanked out with dots rather than being visible, is this normal, is a “reset” required?
Post #644396 Wed Sep 25 2024 8:09pm
jimbg
Do you not have a data sim that you can try?
It looks like you are plugged into the USB next to the drivers seat? This is for CarPlay or uploading maps from a USB stick.
Try using your phone as a hot spot unplugged, you can plug into the one next to the passenger seat for charging.
Do you have CarPlay? Your infotainment system should be on S22 if it is up to date.
Have you downloaded the iGuide app for the manual? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #644397 Wed Sep 25 2024 9:19pm
carlos50
Went out and got one this morning, activated it, git the confirmation it was active, inserted it, just says “mobile data not available”
Land Rover removed all owner info from the car, I reconnected it he car to my account before trying the SIM card option. Nothing is working, and still just fits for MAC & IEMI
I guess I have a problem with the telematics control unit or something then?
Post #644410 Thu Sep 26 2024 12:55pm
jimbg
Have you tried using CarPlay? Then you can use Google maps or Waze and do not need any Land Rover subscriptions.
I am assuming your car is up to date, as you have not said what version you are on? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #644411 Thu Sep 26 2024 1:51pm
carlos50
Sorry I missed that, yes CarPlay works perfectly. Not sure where to find the version though Very Happy
Post #644412 Thu Sep 26 2024 2:25pm
