Home > Technical > L320 front left air blend stepper actuator change
Greg_B
Poland 2008 Range Rover Sport TDV8 HSE Java Black
Hello
I made some tests and front left air blend stepper actuator (LHD) is not working. Made some research and looks like replacing it requires central console removal which is quite complex. However could not find any good guide how to do it. Has anybody did it and could give some advice? I'd like to avoid any pannels/trims cutting etc.
Greg
Post #644288 Tue Sep 17 2024 7:31pm
Greg_B
This is what I found, but important deasembly steps are missing.
&t=309s
Also in the comments there is following tip, but this could the last resort
Driver's side takes about 20 minutes. Remove panel below steering column. Blend door actuator is the lower of the actuators. Snip off a little plastic from the area covering the top of the actuator. Remove three screws and remove actuator. The trimmed plastic does not effect the structural integrity and is covered by the panel when installed. The other actuators you are pointing out are recirc and mode door actuators. Nothing needs programming. Holding two buttons on HVAC panel and turning on the key starts calibration. There are only two temperature blend door actuators. You have wasted a tone of time and are just going to introduce noise when reassembled.
Nobody had problems with air blend stepper actuator?
Greg
Post #644297 Wed Sep 18 2024 12:05pm
