Home > Technical > What is the correct gallery pressure on L320? |
Greg_B Member Since: 21 Aug 2024 Location: Skubianka Posts: 15 |
Hello,
Mon Sep 16 2024 6:59pm |
You explanation looks reasonable, but the question is why after starting the truck the compressor kicks on for some time? Might it be becouse the car is leveling itelf in the night? But the gallery pressure in the morning is almost the same as in the evening the day before...
Tue Sep 17 2024 5:27pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 940 |
My compressor kicks in every time instant the car in the,mornings. The car will sit level after being parked up and locked,,, but will only level down not up so there is a good chance you at be below normal height. Hence the reason it raises when you first start in the mornings,, will also depend on what surface you're parking on,,, it being level or not.
Tue Sep 17 2024 5:51pm |
Many thanks! As I'm ownig my RRS only for 5 months I'm still in the process of learning that car... BTW truck parks in the garage with quite level surface
Tue Sep 17 2024 6:06pm |
Mine is usually parked in the garage on a good level surface but if I leave it for a day or two I can see the front raising when I start up. One of those things you will get used to during ownership.
Tue Sep 17 2024 6:21pm |
Talking about coloured warning indicator lamps, yes, in the morning when starting the engine I got DSC warning with warning message for a second but it is gone immediately. It pop ups usually after the car stays overnight. After driving it for some kilometers and when starting engine it is usually not showing up. I'm suspecig the battery as my trips are quite short and need to make some more observations.
Tue Sep 17 2024 6:41pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
It will run as soon as the car is started since the system will release any residual pressure in the gallery, then pumps up to recalibrate itself. |
Wed Sep 18 2024 12:42am |
I see, thanks. So to gallery pressure at 97-99 KPa during the ride is something in range and there is nothing to be worried about, right? |
Wed Sep 18 2024 7:25am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8959 |
Mine runs every time I start the car. When I park the car, turn off the engine and then lock the car, the car drops a fraction (with a little "puff" noise) and this is then reset to normal height when the engine starts. That means the compressor runs.
Wed Sep 18 2024 8:40am |
Great, I notice the same "puff" with mine, so it looks it "works and designed". |
Wed Sep 18 2024 9:01am |
