Home > Technical > Startung trouble: key won't turn. When it does, it cranks wi |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 325 |
Google the two codes and start from there. It’ll give you some areas to read around and apply to your car.
Wed Sep 11 2024 10:43am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8932 |
P0657 is "Actuator Supply Voltage A circuit/open" i.e. high resistance. Manual suggests running through the guided diagnostic routine. So you need someone who has a suitable proper diagnostic equipment.
Wed Sep 11 2024 4:12pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4940 |
All those codes do seem to be related to the transmission control module.
Wed Sep 11 2024 5:05pm |
