Home > Technical > 06 supercharged not starting |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
I chased a similar fault on my v8 d3 same engine and fuel system.ptetty much. It had me going for a while very random it was to like you I was about to suspect the fuel pump.
Thu Sep 05 2024 9:13pm |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 160 |
Thanks for reply, I'll check the cranking voltage tomorrow, Its almost like a lazy start, cranks and cranks ,kinda starts or does'nt if that makes sense. |
Fri Sep 06 2024 4:46pm |
Quick update
Sun Sep 08 2024 7:06am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4980 |
If blue smoke it could be oil
Sun Sep 08 2024 9:34am |
I'll try the battery disconnect |
Sun Sep 08 2024 10:34am |
Is it normal for engine to stop when the oil cap is removed ?
Sun Sep 08 2024 5:59pm |
Well, replaced the pcv valve, but turned out to be fuel contamination.The fuel station admitted liability, was also hundreds of posts on facebook concerning the said garage, regarding broken down cars.
Mon Oct 28 2024 8:08pm |
Mon Oct 28 2024 8:15pm |
