![]() | Home > Technical > change the new instrument cluster |
It contains the imboliser code, so it would need programming to match your key etc.
Upupup Member Since: 02 Sep 2024 Location: Bangkok Posts: 4 ![]() ![]() ![]() |
Do you have any programs recommend? |
No
Thank you |
I notice some of those are for a Vogue, so don't order one of these with the wrong looking dash |
Thanks |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Might be easier purchasing a Gap tool and reprogram the system |
Check with gap you can actually do that before purchasing. |
supernatural Member Since: 04 Sep 2024 Location: Rosbery Posts: 10 ![]() ![]() |
complete kit sounds like a solid option if you can't find a way to program it. |
Seriously, you need to pull codes to see what's really happening. We assume it's dash related, and in all probability it is. But then, can we be sure without pulling those DTCs. |
