Home > Maintenance & Modifications > Brake disc dust shield replacement...how to go about it?
lemon
I need to replace my rear brake disc dust shields, one was causing noise and bending it out the way resulted in it crumbling up and I presume this has also caused the parking brake to give a loud screech sound and an error message.
Anyone changed these and is it gonna cost loads? I heard somewhere that everything needs to be removed but also that some people cut them to get them on. Advice from those in the know would be great. I am going to be changing the rear discs and pads myself very soon so maybe I can do it at the same time myself...
Post #643796 Sat Aug 17 2024 11:10am
Changing them correctly is a world of pain.
Yeah you can cut them in half. And if you have a welder tack them together in a couple of places.
Do some research for the best place to cut them. Vertical or horizontal. Need to be strong for the parking brake
Post #643798 Sat Aug 17 2024 1:58pm
Photo of the two piece replacement backplates you can buy in the States, unfortunately don't think you can get them in the U.K unless you ship them in. Might help with where to cut them if you went that route.
Post #643802 Sat Aug 17 2024 6:30pm
Disco_Mikey
It's not a world of pain. Just need the hub removed and the bearing pressed out and in again Thumbs Up
Post #643803 Sat Aug 17 2024 6:46pm
NoExpert
DM, have you been able to press out a rear wheel bearing and not murder it? I just changed one of my rear wheel bearings and if it wasn’t trash when I started it certainly was when I got it out. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #643805 Sat Aug 17 2024 9:08pm
lemon
Thanks for this could be useful. I saw most people just cut them directly down the middle top to bottom though...
Post #643812 Sun Aug 18 2024 11:40am
lemon
I already bought these with the intention to cut them...
https://www.ebay.co.uk/itm/296304170291
Post #643813 Sun Aug 18 2024 11:43am
