Home > Maintenance & Modifications > Heated windscreen
rp1555
Heated windscreen
I am not a fan of the heated windscreen which seems to come as stanadard for all new RRS (PHEV) models. Do you know if a non-heated windscreen can be fitted as a factory order or by a third party provider?
Post #643594 Mon Aug 05 2024 3:45pm
jimbg
As they all come with a heated screen then there is unlikely to be a non heated screen made by anyone as they would by replacement screens.
What's wrong with heated screen? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #643595 Mon Aug 05 2024 3:53pm
rp1555
I feel dizzy when looking through it. I had the same
issue with the Jaguar XF I previously owned and had to swap out the windscreen.
Post #643597 Mon Aug 05 2024 4:16pm
I think the heated windscreen is/was an option on vehicles supplied to hot locations - Middle East, Australia, etc., - so it ought to be possible to get an unheated screen. Probably take a lot of work, however, as UK glass replacement companies won't have them in their stock line for obvious reasons.
You probably need to speak to Land Rover directly and try to buy an Australian screen directly from them. That way, any attached bits will be correct for a RHD vehicle as Australia drives on the left like we do. 2012 SDV6 - it's missing a couple of cylinders
Post #643614 Tue Aug 06 2024 9:08am
I would think the factory should be able to do it to order, if non electric models have plain. Worth asking.
On the other hand it maybe a requirement. i.e without it, will the blower cut in to sufficiently clear the windscreen? They have a mist sensor, so the logic may not be programmed to turn the blower on, if it thinks the heater will do it.
Worth talking to dealer/JLR as a special order and see what they say, even if you don't intend to go with their expensive path
Post #643616 Tue Aug 06 2024 9:55am
