Home > General (L494) > L494 SDV6 84month timing/cam belt change |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 118 |
19 plate SDV6? Thought they had changed over to straight sixes by then. Anyway, if it is an SDV6 the belt change is at 7 years or 112k miles. Ive got a 17 plate and recently had it done by Land Rover for £1.4k. |
Sun Jul 28 2024 10:13am |
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 53 |
Give these guys a look - they have a good reputation: https://glenrands.co.uk/ |
Sun Jul 28 2024 10:18am |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 245 |
If its the usual 3.0 tdv6 - you can just get the timing belt done at the back where the manifolds are, the other belt is the fuel pump belt if this goes you would just come to stop when driving if it every did go, they usually check it when doing the timing belt, it wouldn't damage the engine. Most indys are usually £700-£800 on just the timing belt swap. |
Mon Jul 29 2024 8:02am |
Barnsnape1 Member Since: 31 Jan 2021 Location: Horsham Posts: 12 |
I second the recommendation of glenrands
Mon Jul 29 2024 10:30pm |
