Home > Technical > Fault code P1247 Turbo Boost Pressure Low |
Pottern Member Since: 21 Sep 2022 Location: Yorkshire Posts: 5 |
Hi everbody
Wed Jul 17 2024 9:06am |
JAMO1282 Member Since: 18 Jan 2024 Location: Cumbria Posts: 19 |
Hi did you ever sort this? I have the same fault code on mine 😫.
Wed Sep 25 2024 4:21pm |
Hi unfortunatley the Turbo sucked the oil through and the engine ran away with its self it will still run but undersidered if i want to spend £5k having new turbos fitted on a vehicle only worth about £6k. It is still a lovely car and i enjoy driving it i have already had a replacemnet recon engine fitted as the crank snapped just under two years ago. the engine has only done approx 20,000 miles. would like to find someone who could do turbos for me for about £2k then i may get it repaired. |
Wed Sep 25 2024 4:29pm |
