Home > Faults & Fixes > Ace pipes replaced (pics) now juddering |
Tom Davison Member Since: 19 Oct 2022 Location: Norfolk Posts: 15 |
Yes it looks a very smart job, and presumably opens up the pipe replacement to a more DIY solution rather than body off job? |
Sat Aug 19 2023 7:48pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 402 |
While we have so many interested people on the thread have i not heard of removing the pump ,fitting a shorter belt to disable the system. What about warning lights.
Sun Aug 20 2023 7:46am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4376 |
ARC pipes are not body off to replace
Sun Aug 20 2023 8:06am |
Quote
Sun Aug 20 2023 8:12am |
Is that a “not a body off, but still need to lift?” There’s no way I could get my pipes in on the 5.0 without bending the pipes, lifting the body a few inches or cutting them, the bends in the pipes exceeded the space available. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Sun Aug 20 2023 6:38pm |
Cchewy Member Since: 16 Apr 2024 Location: Surrey Posts: 5 |
Hi All, Does anyone know the pipe size of the ARC pipes. Looking to pick up some compression joiners and should imagine a 10mm coupler will do but thought as you have done this job before you could possibly know for sure the size…. Thanks in advance. |
Sat Apr 20 2024 4:37pm |
It’s been quite a while but I think it was 10mm. 2019 5.0 SC SVA (Current)
Sat Apr 20 2024 5:27pm |
Thanks for getting back to me. Ended up popping into screwfix to buy a micrometer and it is as near as damn it. |
Sat Apr 20 2024 5:34pm |
SuperC Member Since: 24 Feb 2016 Location: Midhurst, West Sussex Posts: 67 |
Hi All,
Mon Jun 17 2024 4:34pm |
Final thoughts on this to round off my experiences with JLR and the part being out of stock for over a year. I got the car back today and I managed to fit a different part # that fitted perfectly, without any alterations at all. It is LR019908, Genuine OEM LR019908 - Land Rover Kit - Repair (LR019908) part for Range Rover Sport 2005 - 2009. Authentic Land Rover Part. It fits my 2012 with no issues, no cutting pipes or anything and its in stock with JLR.
Thu Jul 11 2024 6:45pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 331 |
Thanks for reporting back |
Thu Jul 11 2024 7:40pm |
