![]() | Home > Faults & Fixes > Ace pipes replaced (pics) now juddering |
Tom Davison Member Since: 19 Oct 2022 Location: Norfolk Posts: 15 ![]() ![]() ![]() |
Yes it looks a very smart job, and presumably opens up the pipe replacement to a more DIY solution rather than body off job? |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
While we have so many interested people on the thread have i not heard of removing the pump ,fitting a shorter belt to disable the system. What about warning lights.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4442 ![]() ![]() ![]() |
ARC pipes are not body off to replace |
Quote
Is that a “not a body off, but still need to lift?” There’s no way I could get my pipes in on the 5.0 without bending the pipes, lifting the body a few inches or cutting them, the bends in the pipes exceeded the space available. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Cchewy Member Since: 16 Apr 2024 Location: Surrey Posts: 5 ![]() ![]() ![]() |
Hi All, Does anyone know the pipe size of the ARC pipes. Looking to pick up some compression joiners and should imagine a 10mm coupler will do but thought as you have done this job before you could possibly know for sure the size…. Thanks in advance. |
It’s been quite a while but I think it was 10mm. 2019 5.0 SC SVA (Current)
Thanks for getting back to me. Ended up popping into screwfix to buy a micrometer and it is as near as damn it. |
SuperC Member Since: 24 Feb 2016 Location: Midhurst, West Sussex Posts: 78 ![]() ![]() ![]() |
Hi All,
Final thoughts on this to round off my experiences with JLR and the part being out of stock for over a year. I got the car back today and I managed to fit a different part # that fitted perfectly, without any alterations at all. It is LR019908, Genuine OEM LR019908 - Land Rover Kit - Repair (LR019908) part for Range Rover Sport 2005 - 2009. Authentic Land Rover Part. It fits my 2012 with no issues, no cutting pipes or anything and its in stock with JLR.
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Thanks for reporting back |
DorsetJag Member Since: 20 Oct 2024 Location: Poole Posts: 8 ![]() ![]() ![]() |
Hi, looking at the photos it looks like the gap behind the wheel arch where the body mount is is quite narrow. Can you fit the pipes through without lifting the body?
