Home > General (L461) > Sun roof stuck open
Johnson
Belgium
Sun roof stuck open
First day of week trip in the UK and faced with a stuck open sun roof
It slides to close but at 5cm of closing opens up again to mid point.
Trying to close again it goes forward and back few centimetres and again when at 5cm of closing opens again to midpoint.
Roadside assistance stopped by and worked on it for 45’ and could not solve it
Annoying - RRS MY24 with 4K miles Sad
And stuck now with a €100K+ like the attached picks (if they manage to upload)
I’m at LA22 0LQ and was thinking of trying to contact Kentdale Land Rover
I’m here for a week so hope they could fix it
Any ideas on the issue or the “try to fix it”-solution (ie contacting Kentdal)?
Thank you forum Bow down
Koen
Post #642800 Sun Jun 23 2024 6:23pm
bimjim
Bad luck. Have you tried Land Rover Assist? I would try that first. 2023 P440e Dynamic SE
Post #642804 Mon Jun 24 2024 8:26am
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Sounds like calibration - have you tried global close and checked the iGuide? There is a reset procedure
Post #642810 Mon Jun 24 2024 10:29am
Johnson
Belgium
thank you
I have called LR assist and send a technician- tried to find a solution for 45’ without luck
Called out to 2 LR service centers but very strict on not having possibility to look at it. (Not even faintest effort Sad
I have not tried the global reset - will look for it!
Thanks
Koen
Post #642814 Mon Jun 24 2024 12:04pm
Johnson
Belgium
Hi all
made it back - drove 1000km with an open roof (thank you Land Rover)
For those interested - the motor of the roof mechanism broke (seems not uncommon) and because of that, when closing, the roof comes down to soon and the rails hit the fixed glass part of the panoramic roof. With the rails on the glass roof the roof will never close fully.
So now; broken mechanism and broken glass panoramic roof.
A big shout out and thank you !!! to Ryland Land Rover in Stoke on Trent.
I showed up asking for some help - the service person went to find a mechanic, came out - had a look, took the car back to the workplace and (was apologetic that it could not be fixed) managed to close it as much as possible.
This on comparison to Land Rover Lakedale and Kentdale where they did not even bother to understand the problem at service reception!
Safe driving
Koen
Post #642927 Sat Jun 29 2024 7:53am
