Home > General > Screen washer
MikeBell36269
Screen washer
Hello
When I press the front washer the wipers start but the water squirms the rear window. The rear does the opposite rear wipers squirt to windscreen.
Hoses on wrong pump or wires wrong? Where would you look?
Post #642748 Thu Jun 20 2024 3:16pm
hose on the wrong way.
Trypical problem if the body has just been off
Post #642749 Thu Jun 20 2024 4:52pm
MikeBell36269
Have not had it long so dont know if body has been off. Only found out when i tried to wash the rear screen, since wipers work on auto for the front.
Will swap hoses, is it wheel off, access under the passenger wing?
Post #642750 Thu Jun 20 2024 5:15pm
yes. May not need to take the wheel off, but it will need jacking up
Post #642751 Thu Jun 20 2024 5:40pm
