![]() | Home > In Car Electronics > Facelift screen/head units |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Do you have the TV tuner already installed? if not you will need that as well, on a MY12 it is under the drivers seat I think, mind you the TV option is about as useless as a chocolate teapot, just a gimmick, the bms system will switch it off after a few mins. unless you keep the engine running.
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
Thanks Col - so scrap the TV option. Is the rest of the display stuff any different/better or worth having over the MY10 ? |
I personally think the later interface looks visualy more pleasing to the eye, does it do any more than the earlier version, can't really answer that but I suspect not.
You can’t easily interchange 2010 and 2012 displays |
Thanks Andy - will leave as is |
