Home > In Car Electronics > Facelift screen/head units
JonnyCJ
My MY10 head unit has dab/radio/CD/sat nav etc and is the touch screen version which is a vast improvement on the 2005 version I had.
I’ve seen what looks like a better unit from a 2012 Autobiography.
Question is, are the facelift screens/head units interchangeable ? So for instance, if I wanted a unit which had TV is it a straight swap out ? Would I be upgrading or just getting a different style unit ?
Had a Google but can’t see anything definitive amongst the sea of CarPlay aftermarket options.
Thanks as ever !
Post #642729 Tue Jun 18 2024 10:47pm
Do you have the TV tuner already installed? if not you will need that as well, on a MY12 it is under the drivers seat I think, mind you the TV option is about as useless as a chocolate teapot, just a gimmick, the bms system will switch it off after a few mins. unless you keep the engine running.
Post #642731 Tue Jun 18 2024 11:43pm
JonnyCJ
Thanks Col - so scrap the TV option. Is the rest of the display stuff any different/better or worth having over the MY10 ?
Post #642734 Wed Jun 19 2024 7:19am
I personally think the later interface looks visualy more pleasing to the eye, does it do any more than the earlier version, can't really answer that but I suspect not.
Post #642737 Wed Jun 19 2024 7:52am
You can’t easily interchange 2010 and 2012 displays
Post #642739 Wed Jun 19 2024 8:10am
JonnyCJ
Thanks Andy - will leave as is
Post #642752 Thu Jun 20 2024 5:58pm
