Home > Maintenance & Modifications > Alternator change 2010 sport
micknolan
Trying to change alternator on sport , 2010
3.0l
All the guides and help videos showing every fan cowling apart from mine , got all side covers off drivers side also plate front bottom just struggling to remove cowling to get to fan
Any ideas anyone seems to be bolted to radiator all way round
Any guidance thanks
Post #642696 Mon Jun 17 2024 4:31pm
Pistnbroke
Can you not get to it from underneath via the smaller front cover ? Mine is a 2009 2.7 ..nothing like what is in the photograph Always listen to old people or when they die you will live on in ignorance.
Post #642708 Tue Jun 18 2024 7:52am
AndyCHO
Australia 2010 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
3 litre is different.
You can remove the section of the shroud. It clips on but is a cow to get it off.
Once you have it off then you have the joy of getting the fan off... have you got the correct holding tool and spanner?
Apparently then it is easy Smile
I spent 2 days trying to change mine from underneath and couldnt get it done... I sin=mply couldnt get to the main battey connection on the back of the alternator and the cable was so short it wouldnt allow the alternator to be moved forward enough to get to the nit to undo the cable so it defeated me but ended up not needing to be replaced anyway.
Good luck with it.
Post #642710 Tue Jun 18 2024 8:26am
micknolan
Yes seems very tight in there, what was problem with yours if not alternator
Not charging.
Thanks
Post #642711 Tue Jun 18 2024 8:39am
micknolan
Is there few things to check before thinking it’s the alternator
Post #642712 Tue Jun 18 2024 8:44am
Pistnbroke
Faulty alternator ?
Check battery voltage with engine at a fast idle ...1-2000 rpm should be 14v ish.
Is the warning light ON...check at night . faults show as abnormal behaviour. Always listen to old people or when they die you will live on in ignorance.
Post #642713 Tue Jun 18 2024 10:38am
micknolan
Yes got charging system fault on dash
When it came on just drove back home and parked up so lucky
All errors came up and dash etc and cut out on way back home
Went to start once back in drive, and nothing, jumped car starts and runs for 4-5 mins then cuts out dead battery
Changed battery, will work for couple of days then same dead battery
So I assume it’s alternator, have tried jumper cable from block to negative on battery just in case bad earth
But still the same
Will try revs at 2000 and check voltage at battery later
Thanks
Post #642715 Tue Jun 18 2024 11:25am
AndyCHO
Not charging.
Thanks
Mine was more related to some faults showing up which "could" have been related to Alternator / low charge rate but after abondoning the alternator change and having it checked by a Battery place all was well.
I still have the fault lights (3 Amigos) but I have 14.5v showing pretty much all the time when running on mine. I have a voltmeter as part of a dual USB mount where the lighter used to be.
Fault finding electrics in these things can be challenging Smile
Did you reset the BMS when you changed Batteries? Make sure you check all the ground connections etc... Faulty grounds can cuase a myriad of issues.
Post #642732 Tue Jun 18 2024 10:45pm
Pistnbroke
If the cable was tight you could have cut it to get the alternator out and then extended it so you could connect it before replacement.
The first thing you do before even thinking about replacement is to check the output voltage Always listen to old people or when they die you will live on in ignorance.
Post #642738 Wed Jun 19 2024 6:56am
AndyCHO
Well you obviously havent been underneath a 3 litre V6 Range Rover Sport... Not sure how I was going to get cutters into the areaa behind the Alternator to cut the heavy duty cable when I couldnt get to the nut to undo it.... there is a large turbo in the road and the only other option was to start undoing the main cable to the starter and by that stage I had had enough... I am no longer young enough or pig headed enough to tackle those sort of jobs... apparently it is far easier from above... given the right tools.
As for checking voltage... I did have a volt meter in the system but it was faulty..and all the info says it isnt too hard to change the Alternator... so I gave it a go. The info on the internet was wrong.... who would have thought....
Anyone in Australia need an alternator for a 2010 RRS 3 litre?? I have one at a good price, never fitted lol
Post #642740 Wed Jun 19 2024 7:11am
NoExpert
Alternator on a 3.0 is a pain, but totally doable from the top. Last one I did was a Disco 4, think it took about an hour to get out and an hour to get back in. Getting the cable off is a chore, pretty much doing it by feel with a stubby wrench. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #642741 Wed Jun 19 2024 2:38pm
micknolan
Yes did think top as no room to get alternator out one bolts out via bottom or side , will be sorting the weekend if weather holds out thanks
Post #642743 Wed Jun 19 2024 3:51pm
NoExpert
Remove the fan, L plastic intake pipe, intake hose and airbox. This gives you a bit more room and visibility in there. Even with the body off access is a pain.
Post #642753 Thu Jun 20 2024 5:55pm
micknolan
Any idea how to get to other end of l pipe remove seems impossible 😔
Thanks
Post #642784 Sat Jun 22 2024 8:55am
