Home > General > My new to me 2006 supercharged fixes and faults.
Page 8 of 9 <123456789>
JonnyCJ
It does indeed - makes a handy receptacle for all the wires that come out of the top of the dash cam mirror.
Post #640869 Tue Apr 02 2024 3:35pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Continuing with the colour coding I bought a lower tail gate trim panel off the Bay. De badged it rubbed it down under coat, base coat, clear coat. Wet flatted with 2000 grit bit of cutting compound finishing cut n polish.
Post #641310 Fri Apr 19 2024 8:51pm
Lrstaylor
New door handle covers they came in gloss black so more of the same. Rub down, undercoated, base coat, clear coat. Can't put the polisher on them but they came out pretty good with a final heavy coat of clear.
Post #641390 Mon Apr 22 2024 5:54pm
Lrstaylor
Continuing the colour coding theme new side vents arrived I had a bit of basecoat left.
Before
After
Practise my clear coat blend on my old bumper while I had the clear rattle can to hand.
Wet sanded a section.
Clear coat applied medium coat not to heavy.
Post #641873 Sat May 11 2024 8:45pm
Lrstaylor
Fitted they look darker in the photo but there not it's the lighting effect
Post #641877 Sun May 12 2024 11:33am
Lrstaylor
Replaced os rear door actuator as it unlocked for the 1st time in months with help from a finger and a press of the dash unlock button.
Easier than the front with only x1 clip holding the glass in place thankfull for a dry day.
Post #641880 Sun May 12 2024 4:13pm
Lrstaylor
Moving onto some minor blemishes on the body work before I repaint the roof.
Os rear door had some scabby clear coat peel I had previously wet sanded and sprayed a bit of base coat to protect it over winter.
Here it is before I gave it a wet sand.
I hit it with a lite dusting of base coat and let it dry.
Couple Coates of clear I'm please with it so far will give it a couple of days to harden properly then wet sand n polish it.
Post #641957 Tue May 14 2024 8:28pm
Lrstaylor
Found a warm dry day last week with almost no breeze so rattle canned the roof I rubbed it down the week before half of the roof was undercoat were it had lost paint.
Happy with the finish a few coats of base colour then 4 coats of clear. Gave it a wet sand couple of days later n polish will need to repeat but I'm happy with it.
Post #642418 Tue Jun 04 2024 9:08pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Looks fantastic
Post #642422 Wed Jun 05 2024 6:16am
Lrstaylor
Yeah not yo bad for rattle cans and an on the driveway respray.
Rolling with laughter
Post #642439 Wed Jun 05 2024 3:18pm
Lrstaylor
Time to fix a puncture
Post #642470 Thu Jun 06 2024 4:54pm
Lrstaylor
Time to decide if I want to upgrade the sc pulley or not ????
Post #642567 Tue Jun 11 2024 8:01pm
skid1963
upgrade or replace do you mean?? thought you'd sorted it mate 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #642570 Tue Jun 11 2024 8:50pm
Lrstaylor
Upgrade it mark I'm just trying to decide if it's worth the extra money or not
Post #642580 Wed Jun 12 2024 10:52am
JonnyCJ
I had the mild upgrade on my old 4.2 and it was ballistic quick !
Post #642590 Wed Jun 12 2024 4:06pm
