Home > Faults & Fixes > New RRS owner 3 trouble codes |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4891 |
Surprised your getting that egr fault code in a 2005
Sun May 19 2024 9:17am |
jonnwhite Member Since: 18 May 2024 Location: Bognor Regis Posts: 5 |
Thank you!
Sun May 19 2024 10:58am |
These are the egr pipes. One each side down to the EGRs
Sun May 19 2024 12:00pm |
Fair to say I still have those pipes. Assume I’d need to remove the pipes to see if it’s been blanked?
Sun May 19 2024 1:12pm |
If the pipes are present, they are likely 90% functioning.
Sun May 19 2024 5:08pm |
Got a bit of an update, the guy with the Launch wasn't in but managed to have a good look on the car.
Sun May 19 2024 7:30pm |
Hey me again, So had a full day of working on the car, including a full service, blanking both EGRs (They were nasty) gave everything a clean and making sure to remove the butterfly. The final job was to work on the turbo actuator. I managed to get it to move only a small bit (It's jammed solid a long screwdriver and some gentle taps with a hammer didn't make it budge). It has deffo moved however i now can't seem to move it any more, since moving it I've not got a new problem which i think is related to the actuator moving slightly. With the EGR delete the car runs much better and allot less smoke. The new Code is P0046(00) i took the car for a drive and that code piped up, however, it didn't come back after the code cleared. I'm wondering if my moving the actuator has caused the vanes to now stick open, I'm also getting a sort of dump valve sound when revving the engine on the comedown which is new today and apparently can be the turbo/actuator. Any tricks to free the actuator or am I looking at a new turbo? The gap is a bit tight and many tools wouldn't fit! Made a makeshift hook tool to try and push/pull the actuator but it won't budge. Many thanks Jon |
Sat May 25 2024 10:28pm |
