![]() | Home > General > Removal of center console in L320 my2012 |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
YouTube is your friend there are some good clips on "how to" |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 431 ![]() ![]() |
Did mine on Monday. Unclip the rectangular cd cover by slipping a thin blade under the middle and prising out.
keith63 Member Since: 02 Sep 2019 Location: south staffs Posts: 86 ![]() ![]() ![]() |
cheers Johnny
It’s not very hard. If you don’t have trim removal tools your fingertips will hate you. Do NOT pry up at the very end under the cubby lid. Pry just ahead of this. Prying at the very end can break the trim piece. Do NOT tilt it side to side at an angle, you will break off the tabs that lock into the clips. It takes a new trim piece to fix this as well.
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 77 ![]() ![]() ![]() |
I'd go further than that and say DO NOT attempt this unless you have the necessary trim tools. They cost just a few quid and make a 'tricky and I'm likely to break something' job into a very simple one.
Get some decent ones as well. The cheap ones snap. |
thanks gent for your advice
