Home > Wheels & Tyres > Defender wheels on L494 |
Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 38 |
I asked a similar question a while ago, no answers.
Thu May 02 2024 7:00pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
There is nothing specific about big "Red" brakes, they are simply 6 pot brembo's painted red, some svr's and other models are painted Blue, others simply have the Land Rover logo on them, I think most of the later L494's had them one colour or another anyway, the wheels on the Sport will be 5 x 120 PCD, can't remember the bore diam offhand but I think it is 72.56mm though. There a few different offset's though depending on rim diameter/style etc. The option for 19" rims that fit over the 6 pot brembo's used to be very limited.
Thu May 02 2024 9:09pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
I'm not sure the L494 (at least at the end of its life) was even offered with 19in rims was it Col? 2012 SDV6 - it's missing a couple of cylinders
Thu May 02 2024 10:09pm |
Not sure either Wayne, should have stated that I was just referring to about 19" rims fitting over the 6 pots in general, could be the new defender 19" have enough clearance to fit over the brembo's, would have thought someone may have tried by now.
Thu May 02 2024 10:24pm |
Villager Member Since: 24 Aug 2023 Location: Blackburn Posts: 10 |
I chickened out and went for 20" Discovery 5 wheels instead. Just as well as there's very little clearance over the calipers even with those.
Fri May 10 2024 4:27pm |
wheelfinity Member Since: 10 Jul 2024 Location: London Posts: 12 |
Those rims fit fine on old Vogue and old and new Disco, so I am assuming new RRS should be OK as well?
Wed Jul 17 2024 3:42pm |
RR55 Member Since: 30 Apr 2024 Location: Down Posts: 7 |
Defender L663 style 5098 20" wheels onto my 2016 4.4sdv8 RRS..... ok so haven't seen these wheels on an rrs locally and maybe there's a reason I'm missing, according to wheel-size.com they will fit with 255 x 55 x 20 tyres leaving circumference very close to oem 275x45x21. Oem wheels have 47 offset on 9.5j rims, these have 41.5 offset on 8.5 rims and with the 255x55 tyres on its showing a positive scrub of 4mm but with 44 offset its 0 scrub..... Also 0 scrub with 275x55x20 BUT bigger circumference...... so my question is will the slight positive scrub be better than messing up speedo and 30mm bigger diameter |
Mon Nov 18 2024 2:01pm |
These will show what I've found if it helps.... could be making a mountain out of a molehill but need advice from someone who knows 🤷♂️ |
Mon Nov 18 2024 2:04pm |
Mon Nov 18 2024 2:08pm |
