![]() | Home > General (L461) > Buzzing noise when vehicle moving from Drivers Door |
rsr Member Since: 10 Aug 2022 Location: Manchester Posts: 31 ![]() ![]() |
I have something similar started recently, I don't think mine is electric as when I put force on the upper door card it goes away. Very annoying though. |
Rowdie Member Since: 14 Jan 2015 Location: Uk Posts: 188 ![]() ![]() |
I will give it a try. Do you think it’s a vibration then ??? |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 295 ![]() ![]() ![]() |
Mine vibrates also but when I press on the handle it goes away. Only at slow speed and over non smooth roads. |
Hi Rowdie Mine does is at different speeds, it's more noticeable on bumpier roads which is most of the time nowadays! If i press in the area in the image it tends to stop. ![]() Cheers |
Thanks RSR |
Mine going in to dealer for door card removal to investigate. Something vibrating in there as doesn’t happen with other doors. |
if anyone gets any useful info on what their noise is, please could they post it here ? Would be really grateful to have some guidance before it goes in to the dealers.
